-   -   Trans Linkage Issue (https://blazerforum.com/forum/engine-transmission-35/trans-linkage-issue-15794/)
85v8blazer Dec 30, 2007 03:20 PM
Trans Linkage Issue
I just recently bought an 85 s10 blazer that has already been converted into a V8 with a 700r4 tranny.. The main problem is no matter what gear I shift the lever into the trans stays into what seems to be neutral. No matter what gear it will roll freely. Any suggestions I will gladly accept.
Chevy Lover Dec 30, 2007 04:16 PM
RE: Trans Linkage Issue
Have you checked the trans oil level and have you checked that the shifter shaft on the trans actually moves when you move the shift lever inside the truck.
If these are both ok, then it's possible something has come loose inside the transmission and you'll probably have to remove the pan to have a look.
85v8blazer Dec 30, 2007 09:47 PM
The fluid is fine but thats as far as I have gotten so far.. I just bought it a few days ago and its been raining everyday since so no real chance to get underneath it. I was just trying to get a few starting points. Thanks
Blazin_Jason Dec 30, 2007 09:54 PM
Yeah like CL said, check the bolt that holds the rod tight. It may have become loose and won't shift the tranny. Where you located?
85v8blazer Dec 30, 2007 10:28 PM
I will check that tomorrow. I am located in Georgia. That is just the first problem I have come across. I am expecting a few more but I knew it was a project the price was right and I have always wanted a V8 conversion s10 blazer so I couldn't pass it up
Blazin_Jason Dec 30, 2007 10:46 PM
Cool post up some pics sometime. Were you able to test drive it, or was it purchased with some work needed? Are you familar with the 700r4 trans? Hopefully the TV cable is setup properly.
85v8blazer Dec 30, 2007 11:01 PM
I wasn't able to test drive it, 2 flats and no spares but I knew it needed some work. I heard the engine run and that sold me on it. Very good running so its worth the work.. I will post pics tomorrow just kinda hard to take them in the rain lol. I know nothing about the tv cable never messed with a 700r4. Any tips for me?
Blazin_Jason Dec 30, 2007 11:12 PM
Was it being driven before? The TV cable is very important in these trans. It lets the trans know when to shift/down shift etc. It controls a valve in the trans to regulate pressure. I don't know too much either, but the TV cable is quite important. Maybe do a search about them. v8s10.org is also a good site for v8 trucks.
85v8blazer Dec 30, 2007 11:17 PM
it has been sitting for a few weeks but it was being driven before. But definitely thanks for the ideas to check out. I would like to get it up and running in the next few weeks.
Hanr3 Dec 31, 2007 08:44 PM
keep posting information.
The more you post the better we can help you.
