| willyman82 |
01-24-2011 06:34 PM |
It sounds like you have a problem with the tcase actuator if you have already checked the vacuum lines and vac switch on the TCase. The tcase actuator may not be an easy part to get down under. It is actually a motor, gearbox and encoder all in one assembly. I took some detailed vids when I rebuilt my actuator. The only difference with yours is that there will be an encoder of some sort inside the housing. The encoder/motor assembly for the tcase is on the side near the front drive shaft output spline. You have to take the front driveshaft off to remove the encoder/motor module. I will get my $hit together and edit the video and post a YT link in a day or so.
-William
