-   -   transfer case? (https://blazerforum.com/forum/engine-transmission-35/transfer-case-9123/)
bigt 03-04-2007 08:55 PM
transfer case?
I have a 1984 S10 blazer 4x4 with a borg warner 5 speed transmission with a 2.8 v6. I am trying to find out what transfer case they used in it. I can't find any label other than a barcode 604881N and then some more numbers on the case C15510 either ND or NP next to it? I am trying to find the gasket that goes between the transfer case and transmission. Any help would be appreciated. Thanks
Kordog 03-04-2007 11:51 PM
RE: transfer case?
I am not 100% sure what t-case you have, it could bea 205, 207, 208, 231, or a 241. You can use a bead of silicone between the two, instead of a gasket, I have done it this way many a times, with no problems at all. HTH.
Hanr3 03-04-2007 11:55 PM
RE: transfer case?
I am thinking its a NP208, at least that is what is in my '87 2putt8/700R4.
I agree with Korydog on skipping the gasket and using gasket maker, RTV black works very well here.
