-   -   Transfer case and front diff fluid change Question (https://blazerforum.com/forum/engine-transmission-35/transfer-case-front-diff-fluid-change-question-34184/)
Brianator99 08-29-2009 08:57 PM
Soon ill be flushing the radiator, changing the oil,changing the trans fluid, changing the fluid in the front and rear diff, and the transfercase.
Ive of course flushed a radiator, changed oil, and changed the trans fluid and filter.
Now this is my first 4x4 so ive never done a front diff or transfercase.
Any helpful imput?
Thanks, Brian
portcqb 08-29-2009 11:45 PM
Pretty straight forward there is a drain and fill plug on both of them, just drain it out and fill until it runs out the fill hole.
swartlkk 08-30-2009 07:43 AM
You may not have a drain plug on the front diff. In which case you will need a little siphon pump to pull the old fluid out. The same pump will make it easier to put new fluid back in.
Brianator99 08-30-2009 04:17 PM
okay i figured it was straightforward. and i assume the fluids are in the manual.
thanks guys
swartlkk 08-30-2009 04:28 PM
80w90 GL-5 or 75w90 Synthetic fluid for both the front and rear differentials.
As far as the transfer case goes:
  • Dexron III ATF if you have the three button 4wd switch on the dash
  • GM Autotrak II if you have the four button 4wd switch on the dash with Auto4wd option
Brianator99 08-30-2009 05:14 PM
75w90 syn and Dexron III ATF it is.
Thanks.
swartlkk 08-30-2009 06:18 PM
No problem! Let us know how it goes!
