Transmission to the ****ter???
Old Nov 23, 2007 | 09:28 PM
jzcan's Avatar
jzcan is an unknown quantity at this point
Default Transmission to the ****ter???
Hello I have a 95 Blazer s-10 4wd I drive this thing pretty damn hard I admit i do alot of burnouts and spin the tires they grab the pavement pretty hard. Just tonight it was reving out fine shifting fine then all of a sudden i went to stop Took off with the gas to the floor the engine revs up very gradually. Accelerates very slowely. There is no shifting whatsoever. Also now the shifter won't Go into any low gears its stuck at overdrive N,R,P thats it. Did i fry the tranny??
Thanx gueys.
Old Nov 24, 2007 | 12:36 AM
Chevy Lover's Avatar
Default RE: Transmission to the ****ter???
My guess would be that you've broken the converter clutch solenoid valve, this closes the solenoid, blocks the converter feed fluid from exhausting, and creates pressure in the converter feed fluid circuit at the converter clutch apply valve and TCC solenoid valve, locking up your converter.
But that's just a guess.
Old Nov 24, 2007 | 10:40 AM
Hanr3's Avatar
or hes stuck in a higher gear, like 3rd.
Either way your going to need a tranny shop, and a rebuild might not be out of the question.
Old Nov 25, 2007 | 09:00 AM
blznlowxtreme's Avatar
blznlowxtreme is an unknown quantity at this point
sounds like a rebuild is in your future
Old Nov 27, 2007 | 07:34 PM
JB97's Avatar
JB97 is an unknown quantity at this point
I have the same symptoms at the moment (stuck in 3rd gear), butI didnt beat it like you did lol.
GloryImSaved
Jul 17, 2009 09:05 PM
sfesenko
Dec 12, 2008 10:03 AM
