-   -   transmission (https://blazerforum.com/forum/engine-transmission-35/transmission-87750/)
94blazer68 Nov 4, 2014 05:17 PM
transmission
My 94 full size blazer is having tranny problems. Need some help. When it shifts into overdrive the RPMs jump up a few hundred and drops back down. The tranny shifts fine no hard shifts or jerking. It does this if u ease on the gas. If you stomp it it shifts fine. Fluid levels are good. Any ideas what could cause this. Thanks for any help
gtmccormick Nov 5, 2014 01:56 AM
You might what to check the vehicle speed sensor there also a black sensor up on the throttle body that helps control the shift can't remember the exact name
rap Jan 26, 2015 12:04 PM
Any Update
I am having a similar issue with the transmission in my 98 LT 4wd. Did you ever find the issue?
Thanks,
Richard
gtmccormick Jan 27, 2015 11:31 AM
No I ended up parking it till spring when I'm going to pull and replace the tranny because there so problem prone sorry I couldn't be more help if you figure it out I would love to know
Gregg64 Jan 28, 2015 06:29 PM
They are actually very good transmissions and there are a few other things that can be checked. i would before I just randomly replaced the unit. Get the TPS checked first.
gtmccormick Jan 30, 2015 02:26 PM
Checked the tps…the shear number of problems posted here with that tranny shows there not the best I would take the old TH350 any day
newguy Jan 30, 2015 03:26 PM
Have to agree with gregg, they arent bad trans at all.
Gregg64 Jan 30, 2015 03:51 PM
It basically is a 4 speed 350. now they are just electronic. Thats why they are called 4L60E's. A modern 400 is a 4L80E
