-   -   Transmission Cross member hook up (https://blazerforum.com/forum/engine-transmission-35/transmission-cross-member-hook-up-48765/)
daddytech Sep 5, 2010 05:16 PM
got this 97 S-10 2wd Blazer from my best friend who took it completely apart to do an engine replacement in it. problem is that i have the chilton manual for it but it does not show how the Trans Cross member bolts back in on the ends, I could also use some help trying to figure out where all of these sensor connections plug in. the motor that is replaced in this thing now is actually out of an older (est. 93 model) blazer that only had 80,000 miles on it. it is the 4.3 so it should last a LOT longer than that but i put all 97 year model parts on it. the only thing left of the (93) is the block, crank, pistons, connecting rods, oil pump, and oil pan everything else is off of the 97 including the timing chain cover now. I have all of the linkage and everything on the original transmission hooked back up again just not the cross member end mounts and i am lost with that and the rest of the sensor connections, that is all that i have left to get this thing mobile again for my daughter, can anyone help with some pictures for me please?
Greatly appreciated
Jim
aka daddytech
