Transmission Disorder
2001 Blazer 150k miles
First I would like to say I bought this knowing the trans was bad. I am not sure of too many details except that this is the second trans for this vehicle and it has about 75k miles on it.
I was going to use the car for parts but if I can fix it I will have a nice 4 wheel drive to use as a DD or whatever.
After I trailer-ed it home I tried to run it and after about 20 minutes it would loose all forward and rev movement.
I changed the fluid and filter.
The fluid did not have metal flakes in it and does not feel gritty. It does look kind of brown, kinda like clutch material.
This got the trans working again, but now there is a chatter/buck and some slipping when I get over 55mph at a steady cruise. I found a nice stretch of road to test this out. It does this in 3rd and 4th gear.
My guess is the 3-4 clutch pack is worn out.
Has anyone dared to go into the trans and rebuild? If so would you mind sharing your experience?
Thanks
Thanks
I rebuilt mine myself not knowing anything about it. After searching youtube and other forums I had enough confidence to do it myself. Wasnt as hard as people think. The hardest part was getting it out. Took one day to rebuild and one day to reinstall. 7000 miles later its still going strong
Thank you everyone for your input.
OK so I'm a slow worker.
I decided the trans needs to come out and started the disassemble y. I removed as much as I could before removing the cross member. The stater was the hardest to get out, now I know how to do it, still a PIA but I found a little easier method.
A little more work and the trans will be out, and on to phase 2.
