-   -   Transmission Disorder (https://blazerforum.com/forum/engine-transmission-35/transmission-disorder-89149/)
newguy 07-07-2015 05:12 AM
You may know already but you`ll need a new gasket to mount the transfer case to trans also . dealer item, will need VIN number
snuffy 07-09-2015 12:10 PM
I knew I needed the gasket but didn't know it was a dealer item. Thanks
Do you remember what rebuild kit you used?
newguy 07-09-2015 07:32 PM
sorry cant think of it ,but if I remember I`ll let you know
snuffy 07-11-2015 11:58 AM
I think I found my failure.
4 Attachment(s)
So I am starting to put this thing back together. I get to the input housing and load all the clutch packs. To test the operation of the pistons you apply air in the feed holes in the shaft. When I applied air to this hole (3-4 clutch pack) the piston moves and the clutches engage but there is air blowing past the orifice cup plug in the housing, It's the hole in the housing to the right of my hand. I don't think there should air leaking past that cup plug, am I wrong?
Input housing
https://blazerforum.com/forum/attach...ine=1436633881
Air testing.
10-78 edac 07-11-2015 01:49 PM
snuffy 07-11-2015 04:07 PM
Ah so I am wrong, and I just watched that video too.
Thank you so much.
On with the build.
10-78 edac 07-11-2015 10:22 PM
2 Attachment(s)
I'm about to do the same thing. What kit did you end up getting?
snuffy 07-11-2015 11:47 PM
3 Attachment(s)
There's a lot of seals in that kit, I don't know how I am going to use them all
I am following the book, it's pretty thorough.
Attachment 30793
newguy 07-12-2015 02:48 AM
I like the way your doing this, taking your time. Its gonna
work fine when done
10-78 edac 07-12-2015 10:48 AM
I am definitely gonna upgrade the "sun shell gear" while I'm in there.
