-   -   Transmission Fluid Question (https://blazerforum.com/forum/engine-transmission-35/transmission-fluid-question-26476/)
mwacker 01-12-2009 12:00 AM
I just bought a 97 Blazer with 115k on it. The transmission seems fine and the fluid is nice and red. Should I change the transmission fluid, by dropping the pan and replacing the filter and gasket? I doubt the previous owner had it serviced... Which is more risky changing the fluid or leaving it?
swartlkk 01-12-2009 06:49 AM
RE: Transmission Fluid Question
If the fluid is nice and red, then it was probably changed already. If you want to change it again, that is your call. If everything is working properly and the fluid looks good, there may not be a need.
