-   -   Transmission help (https://blazerforum.com/forum/engine-transmission-35/transmission-help-96998/)
Daveed 05-28-2018 11:52 PM
Transmission help
so the other day my 2001 blazer threw codes for both shift soleniods so I replaced them and it seems to be better but it runs high rpms in third gear still.
GreenBlazer2002 05-29-2018 05:46 AM
Have you been through enough drive cycles for any new codes to set yet?
Daveed 05-29-2018 08:58 AM
I drove it around for at least 30 minutes after replacing the solenoids
Transman304 05-29-2018 09:14 AM
What code numbers did you get? Will it shift past third into fourth?
Daveed 05-29-2018 09:15 AM
I don’t remember the codes now. But no it won’t shift from third to fourth
Transman304 05-29-2018 09:21 AM
Just strange to show both solenoids at once. What was it doing before solenoid replacement? What condition was the fluid when you dropped the pan?
Daveed 05-29-2018 09:23 AM
I couldn’t feel it shift into anything it was running high rpms
Transman304 05-29-2018 09:29 AM
It sounds as if it is limp mode. Third gear. Check the fuse. Does the indicator on the dash light up to tell you what gear you are in?
Daveed 05-29-2018 09:30 AM
no I don’t think it does. I’ll check that fuse
Daveed 05-29-2018 06:36 PM
fuse for limp mode isn’t blown.
