Transmission issues?
Old Nov 19, 2013 | 11:04 AM
eaglesean2002's Avatar
eaglesean2002 is on a distinguished road
Default Transmission issues?
I have a 98 4wd blazer that has been running like crap lately. Starts up fine, but when accelerating from a stop, she seems to rumble and shake a bit. Eventually she smooths out and at about 65 mph, the rpm needle goes a little sporadic and doesnt seem to want to go past 65 with out the rumbling and jerking starting up again. At about 65 mph it starts running rough and you can feel the jerking start until you press the gas pedal harder and it eventually stops. Ive recently done plugs and wires, checked all fluids and everything seems in check. does this sounds like a bad ignition coil? or am i losing my transmission?
Old Nov 19, 2013 | 11:06 AM
the check engine light is on an saying there is a misfire
Old Nov 19, 2013 | 11:07 AM
DesertStorm's Avatar
misfire would be ignition or fuel related. not transmission. could be dist cap/rotor, could be spider injector.. i would start with a cap/rotor first since they are much cheaper to replace than the spider injector.
Old Nov 19, 2013 | 09:07 PM
I did want to add that going up hill it seems to lose power and kind of starts jerking
behemoth
May 18, 2010 08:53 PM
loisengleny
Apr 30, 2010 07:47 PM
chrisdavis23
Feb 27, 2010 09:23 AM
GloryImSaved
Jul 17, 2009 09:05 PM
sfesenko
Dec 12, 2008 10:03 AM
