Transmission issues
Hello I have a 1997 blazer with a 4l60e theses are the codes I pulled from it po740 torque converter clutch open circuit po753 shift solenoid a po758 shift solenoid B po785 shift timing solenoid If I pull The transmission fuse it gives me third year and reverse but with the tranny fuse in I only have reverse is there something I can do to fix it or is it just done for? What do you guys think? Thank you |
You have lost the 12 volt signal to the transmission. Are the gear indicator lights in the dash cluster working? |
It is a console shift But the Indicator lights on the consul beside the shifter are working |
There was a bit of a clunk when I lost all the gears but I can still move it in third gear with the transmission fuse pulled |
The transmission is in limp mode with no power to it. It will have 3rd and reverse with no power to it by design. You most likely have an electrical issue. Do proper diagnostic on it before throwing parts at it. Could be just a bad ground wire. Need to have it on a live data stream to see if PCM is commanding the correct information. |
Any idea what to check first? |
Have it scanned with the proper equipment with OEM software capabilities. Not a code reader. Probably a transmission shop is your best bet. |
