Transmission leaking into Transfer Case
Originally posted to 2nd Gen Tech but I'm told it should have gone here:
2002 LS, Automatic & NP233; Transmission leaking into Transfer Case - from searching the Forums, I gather this is a fairly common problem, but I couldn't find any specifics on my model. Since my Haynes Manual is basically useless for this repair, can anyone offer some insight?
- Is there a seal on the Tranny I need to replace too or just on the Xfer Case?
- Anything else I should check to be sure the seal(s) is/are the only problem?
- Anything else I should do while I have the Xfer Case WRESTLED out?! (And ANYone have a good suggestion for getting Transmission Fluid out of your hair?! )
Thanks!
Thanks!
Flyfishen
06-18-2019 11:22 AM
wadespen
06-05-2011 08:14 AM
rustybeast
11-22-2006 12:19 AM
