Transmission noise in first gear
Old Aug 19, 2016 | 11:53 PM
Jalmquist125's Avatar
Jalmquist125 is on a distinguished road
Default Transmission noise in first gear
2000 blazer Lt 4x4 automatic trans. Early today I was backing out of a parking spot and when I shifted into reverse hit the gas and nothing happened. It didn't engage into reverse so I put it back into park then back to reverse again. Hit the gas a bit and nothing happens again for about a second and then it slams into gear and lurched backwards. Now when I drive it around it makes this noise I can't really describe other than a whining noise. It only does this in first gear. After it shifts out of first the noise instantly stops. Also the transmission seems to still be working just fine it shifts fine and everything seems normal other than the noise it's now making.
Old Aug 22, 2016 | 02:18 PM
LesMyer's Avatar
Sounds like a sunshell problem. A known weak link in 4L60E. Mine went out too, was not abusing it even a little bit. Plan on a complete rebuild and don't drive it if you want it to be rebuildable. Also flush trans cooler and lines to get all the metal out in any case.
Old Aug 31, 2016 | 02:39 PM
Transman304's Avatar
Rear planetary gears that are damaged will give those symptoms. May want to drop the pan and take a look for metal.
robrey26604
Sep 19, 2015 02:29 PM
chevyjim
Aug 30, 2013 10:09 PM
cdmcg
Apr 23, 2011 03:46 PM
8five-k5
Nov 10, 2010 01:00 PM
ivannj
Jan 6, 2006 01:12 AM
