Transmission not going in gear
I have a 1994 S10 Blazer 4X4 Tahoe LT, When taking off its strong but when i get to about 20 mph it take a Lil to shift and the from 20 to 35-40 its OK but i let off the gas and hit it again it revs very high and i have to Punch the gas and it still takes a few to shift and its getting really bad i am getting very upset with it and its really important i get it fixed i bought from friend who had it and he always floored the gas so i don't know, Maybe the bands need adjusting becasue of the last owner always flooring it.
Please let me know annnnnyyyyy thing |
RE: Transmission not going in gear
If the fluid is full and has good color to it (red), then you are likely looking at a worn out transmission. Not too good for you... You might want to have it looked at by a transmission shop for confirmation though.
mines having similar issues with mine. what i found out is the kevlar belts on the inside on the transmission are worn out and takes a little more to catch correctly. eventually that belt will wear through enought then snap. causeing the transmission to go out.
Thanks how much does it cost to get a rebuilt on one of these or if i got one from a salvage yard how much would a tranny shop charge me to swap them
honestly i couldnt tell you. im still riding on mine until it does go out. when it does go out i plan on swapping the motor and tranny out of it from one from a 89 4x4 that i took out of my other blazer i had. i know on www.eatmyshift.com you can get a brand new one for about a grand. but thats a performance transmission so you might be able to find one cheaper somewhere else.
No adjustment to bands.
Find a local tranny shop and ask the same question. Tell them what it is doing and they will give a real estimate for your area. I just answered a thread on replacing a tranny and listed all the option pros and cons. Should still be on the first page or so of the tranny forum. |
Thanks guys
Will this fit my blazer? http://racetransmissions.com/store/p...products_id/66
i thought your body style would have the 700R4 but i could be wrong. but if you have the 4L60E then that would work fine.
i dont know what kind of tranny i have i have no idea
| All times are GMT -5. The time now is 10:23 AM. |
