transmission only has 3rd when the fuse is pulled
I just read something about a key won’t come out of the ignition switch and he had no forward gears, I have the same problem my key is stuck and I have no forward gears, I only have 3 if I pull the tranny fuse, could it just be the ignition switch??? Thank you
| All times are GMT -5. The time now is 09:33 AM. |
