-   -   Transmission Problems? (https://blazerforum.com/forum/engine-transmission-35/transmission-problems-96531/)
02BlazerZR2 03-22-2018 10:26 AM
Okay so I purchased a 02 blazer 4.3 auto 4x4 with a bad transmission. My buddy had a good used trans out of his blazer that I got cheap, installed it and shifted smooth for a few weeks. Earlier today I was driving to the gas station and on the way back home the Rpms started jumping up and vehicle was revving like it was in neutral barely pulling. Speedo is also jumping around like crazy but it had done that every now and then before for a few seconds and would work like normal. Any ideas what it could be? I have read that a bad speed sensor could cause this but I’m not sure about it? Any input would be appreciated thanks.
christine_208 03-22-2018 03:06 PM
If the symptoms are coupled, then maybe a speed-sensor. However, if the transmission acts as if it has dropped into neutral with no other funny symptoms, it could be a clutch pack.
newguy 03-23-2018 02:21 AM
any other gears work? I lost 3rd and overdrive but 1st and 2nd worked. It was the clutch pack
Transman304 03-23-2018 06:41 AM
I agree with the other members post on that you have a 3-4 clutch pack failing. The speed sensor will definitely give you drive ability issues but not a slip while moving.
