Transmission for S10 Blazer questions
Blazer (S Series) 6cyl 2.8L T5WC 1988-93
Borg and Warner T5 World Class, aluminum case, cast "1352" - 1st and 2nd synchro rings are multi-piece design This is my transmission I will be getting rebuilt. Does anyone know where I can find specs on it like max torque etc... I searched around online with no luck. The vehicle weight is around 5500lbs and I just wanted to make sure the transmission will take a bit higher power from a rebuilt H.O. 2.8L engine later in time. I imagine it will be fine but its always good to make sure. Thanks in advance. |
| All times are GMT -5. The time now is 09:11 AM. |
