-   -   Transmission shift hard into 1st (https://blazerforum.com/forum/engine-transmission-35/transmission-shift-hard-into-1st-90799/)
Ricco 09-24-2015 01:36 PM
Hello guys I need some help here, my blazer 95, 4.3L W vin, 4 door and 4x4 when slowing down enough that needs to shift into first like making a yield turn or uphill doesn't shift pretty quick, but my concern is that it makes a loud sound (like something engaged) and then it downshifts. Transmission fluid doesn't look or smell burned, levels are good, truck only has 94000 miles.... Truck shift perfect and strong thru all up shifts and downshifts except 1st. In case it helps I drive it only on 2hi.
richphotos 09-24-2015 07:31 PM
what kind of sound does it make, is it possible for you to get video?
Ricco 09-24-2015 08:17 PM
Thanks you for your reply, I think it would be a bit hard but I can try for the benefit or solving this mistery... I will try to do this tomorrow afternoon, and if I'm successful I will post it for you.
Ricco 09-26-2015 10:32 PM
Its been very hard to take a video And drive with out feeling reckless . I know it's hard to describe a noise but it's not grinding noise its more like banging noise that u can actually feel when it happens if your paying attention
odat 09-27-2015 10:41 AM
If you haven't already check the motor and trans mounts also check U joints and for slack in the rear diff
