Transmission shifting backwards??
4L60E is shifting is backwards, P is park N is neutral D is drive, but 3rd gear is 1st gear, 2nd is 2nd and 1st gear is 3rd?!? |
Your MLPS is adjusted incorrectly or the shift cable is out of adjustment. Unhook the shift cable from the transmission. Put the shifter in park and then put transmission lever in park position and and adjust cable to meet the lever. Then adjust the MLPS so vehicle starts in park and neutral.
transman - whats the chances his shift selinoids are wired off and in the wrong positions as just the shifting thu the gears seems backwards and park thu drive seems right?
Originally Posted by odat
(Post 697716)
Anything is possible.lol! I don’t see that being the problem as there is a manifold pressure switch that will monitor the fluid pressure that is being directed by the manual valve. Really interested in what it turns out to be. What does the transmission do if put in D and driven? Shift correctly 1-2-3on it’s own? |
| All times are GMT -5. The time now is 10:20 AM. |
