-   -   Transmission troubleshoot (https://blazerforum.com/forum/engine-transmission-35/transmission-troubleshoot-30164/)
Blazerx85 05-01-2009 09:42 PM
I have a very similar issue as "suckyblazer" It is like first gear is gone but I can put it into first manually. I had it coded and it brought up trans solenoid a couple times. I am hopeing someone here has delt with this and if just changing out the solenoid can solve this or is the trans shot? How hard is the solenoid to change cause while I am in there I was going to change the filter as well. Anyone with info I would greatly appreciate it.
swartlkk 05-01-2009 09:58 PM
Solenoids are fairly easy to change.
Here are the two main shift solenoid A trouble codes:
P0751 - Shift Solenoid A Performance or Stuck Off
P0753 - Shift Solenoid A Electrical
Blazerx85 05-01-2009 10:05 PM
Alright thank you, how many total are there cause if I have to drop the pan and get up in there I would like to take care of all I can
