Transmission won’t shift past 2nd!
I have a 96 Blazer 4.3 4x4. My problem is that the transmission won’t shift past 2nd. I ran an OBD2 scanner on it earlier and 3 codes popped up. P0300, P0440 and P1440. Nothing saying anytime about the transmission. I’ve tried to start in 1st then manually shift to then shift to drive but nothing. RPMs just runs high. With the research I’ve done, I should try replacing the solenoids and the filter. I just wanted to get a couple opinions here! P.s. I don’t know much about the rig. I recently purchased from a friend. I plan to make it an off-road rig but street legal. Anyways, thanks for any help! |
I just checked the fluid. It looks like dark red tint. https://cimg7.ibsrv.net/gimg/blazerf...7cd4c9012.jpeg |
Hopefully Transman shows up, he knows quite a bit about these transmissions
Not going to be shift solenoids unfortunately. Common issue with a failed 3-4 clutches. Going to need replaced or rebuilt. Good luck Brad |
Originally Posted by Transman304
(Post 704394)
I'm curious as well. Mine isn't a daily driver, so when the trans craps the bed, I'm gonna try my hand at rebuilding it myself
There is a lot of great info posted including video links, photos from members, and recently someone even posted a link to a manual for rebuilding the 4L60E.... That and do what Transman says! ;) |
Originally Posted by Jeffvader
(Post 704404)
Dang that sucks. How difficult is it to rebuild one? I can’t afford to buy a rebuilt one right now. And I skeptical of buying a used one from a pull a part. Are there any step by step tutorials? |
Originally Posted by cleburne red
(Post 704412)
Originally Posted by go chevy
(Post 704419)
My Tranny kicked the bucket this past summer, lost high gear, couldn't go faster than like 35/40 mph... I lucked out and found a used 1 at a local junk yard for $300 bucks with a 30 day warranty. It is doing just fine so far :) It actually came out of a 4x4 S10 pickup truck...
Isn't there a simple and easy upgrade for our trannies as well that he might as well do if he's rebuilding it?
I’ve heard something about corvette solenoids... |
I am sharing my preferences for parts for a 4L60E that I use and continue to use in my overhauls. Every builder has his own recipe for parts that give them the desired results. I don’t do patch jobs or very basic overhauls by putting in new clutches and band and call it good. The brands I list are what I have good success with and not saying you must use brand A and not brand B . This is what I use your results may differ. First is a good converter. I have a local converter shop that I use exclusively. Top Line Converter in Pittsburgh PA. 412-464-9985. In the past have used with success converters from. Precision of New Hampton. Florida torque converter. Bushing kit Corvette servo Borg Warner High Energy band Transtec overhaul kit Borg Warner frictions with the High Energy 3-4 frictions Transgo “SK4L60E” shift kit Transgo aluminum accumulator pistons in forward accumulator and 1-2 accumulator. Delco separator plate Sonnax 3-4 return springs Filtran filter Molded piston kit Borg Warner Input sprag Borg Warner Low/rev sprag Borg Warner EPC solenoid Delco shift solenoids Sonnax boost valve Delco reaction shell This is the standard list for every 4L60E. There will be other parts that need replaced that you will find upon tear down. A lot has to do with application and what the transmission is required to do as to what areas need to be addressed . Steels and pressure plates need to be checked and replaced as needed. The pump and valve body have common bores that wear and need reamed and sleeved. Not for the DIY builder as the equipment and tooling is quite expensive to perform these repairs. The shift kit addresses the main wear area with re designed valving . Another area is the rotor,vanes,slide and pivot pin that wear. Planetary pinion bearings and shims will wear. Planets can be rebuilt and the captured Torrington bearing replaced. But again specialized tooling required to press apart. Please ask any questions or mention any parts that weren’t listed. |
(Post 704428)
mines going the same thing. I’m prepared to spend maybe $500 for a used one. But I would hate for it to go out in 6 months. But I’ll do what I gotta do. |
Well it looks like I don’t have to rebuild it. A friend from work has a 98 Blazer and says I can have the transmission. And any other part I need. He says just give him my old broken parts. There’s not many people like that in the world. I’m gonna have to make him a custom knife! |
(Post 704497)
