Transmission won’t shift past 2nd!
I am sharing my preferences for parts for a 4L60E that I use and continue to use in my overhauls. Every builder has his own recipe for parts that give them the desired results. I don’t do patch jobs or very basic overhauls by putting in new clutches and band and call it good.
The brands I list are what I have good success with and not saying you must use brand A and not brand B . This is what I use your results may differ.
First is a good converter. I have a local converter shop that I use exclusively. Top Line Converter in Pittsburgh PA. 412-464-9985.
In the past have used with success converters from.
Precision of New Hampton.
Florida torque converter.
Bushing kit
Corvette servo
Borg Warner High Energy band
Transtec overhaul kit
Borg Warner frictions with the High Energy 3-4 frictions
Transgo “SK4L60E” shift kit
Transgo aluminum accumulator pistons in forward accumulator and 1-2 accumulator.
Delco separator plate
Sonnax 3-4 return springs
Filtran filter
Molded piston kit
Borg Warner Input sprag
Borg Warner Low/rev sprag
Borg Warner EPC solenoid
Delco shift solenoids
Sonnax boost valve
Delco reaction shell
This is the standard list for every 4L60E. There will be other parts that need replaced that you will find upon tear down. A lot has to do with application and what the transmission is required to do as to what areas need to be addressed . Steels and pressure plates need to be checked and replaced as needed. The pump and valve body have common bores that wear and need reamed and sleeved. Not for the DIY builder as the equipment and tooling is quite expensive to perform these repairs. The shift kit addresses the main wear area with re designed valving . Another area is the rotor,vanes,slide and pivot pin that wear. Planetary pinion bearings and shims will wear. Planets can be rebuilt and the captured Torrington bearing replaced. But again specialized tooling required to press apart.
Please ask any questions or mention any parts that weren’t listed.
Bushing kit
Corvette servo
Filtran filter
Molded piston kit
Sonnax boost valve
I hear ya! Junk yard parts are a "roll of the dice" as they say lol... I remember looking at the calendar and thinking, "day 31 is gonna bite me in the butt"
Well it looks like I don’t have to rebuild it. A friend from work has a 98 Blazer and says I can have the transmission. And any other part I need. He says just give him my old broken parts. There’s not many people like that in the world. I’m gonna have to make him a custom knife!
Christian Wallace
07-15-2018 01:19 PM
91 blazernick
05-24-2013 07:45 AM
