-   -   Transmisson issues (https://blazerforum.com/forum/engine-transmission-35/transmisson-issues-28504/)
rjck1979 03-11-2009 01:27 PM
Transmisson issues
Hello, my transmission seems to not shift very well from 1st to 2nd when its very cold out. When its shifting, it seems like its lagging or having a hard time going into 2nd.Its like the rpms are going up and down and its really trying and then it shifts. It only does this for a little bit until it warms up and then it seems to shift fine.By the way the temp is around -25 or colder when it does this.I changed the fluid and filter in the fall and recently checked it and it looks fine.I dont drive the truck a whole lot. Basically it sits for most of the time when the warm weather comes as i drive my camaro most of the time.I only put around 5000 km a year if that. Any ideas?
2003 blazer ls 4x4
88,000 km,stock
rjck1979 03-11-2009 01:29 PM
Its an automatic transmission.
swartlkk 03-11-2009 03:13 PM
Symptom:
1-2 Shift shudder at WOT or delayed / abnormal 1-2 shift
Cause:
1-2 accumulator piston cracked or stuck cocked in the bore
Repair:
A pan drop and inspection of the 1-2 accumulator piston should be done.
rjck1979 03-11-2009 09:28 PM
Thanks for the quick reply. I will see if my mechanic freind can look into this for me.
Cavalier z24 03-11-2009 09:50 PM
Originally Posted by swartlkk (Post 204652)
Symptom:
Cause:
Repair:
where do ya find these things
W2JGA 03-12-2009 06:12 AM
:D He's got people!
No, seriously he has books up the wazoo! Wish I had his library:cool:
swartlkk 03-12-2009 08:56 AM
It is all in where you look! LOL
rjck1979 03-20-2009 12:13 AM
Well the temp is much warmer now and it doesnt do it anymore. I guess thats a good sign.
Cavalier z24 03-20-2009 12:20 AM
Originally Posted by W2JGA (Post 204805)
:D He's got people!
lol i can tell, he has like all the answers to every thing :)
kkillpack 12-23-2009 01:01 PM
I am hearing a whine from under my '03 blaze (4wd). It gets louder as I go faster (above 40 mph). the sound disappears if I put the vehicle in neutral. There is no sound in 1st gear. It begins in 2nd gear on up. Shifting seems fine, and fluid level is correct. It is getting worse by the day.. Any ideas?
