transtrub;
Ya'all may recall my previous post about the shift shaft seal. As it turns out the prior owner of my baby was'nt much of a mechanic. He buggered up the shaft and had the seal in backwards. Anyway, since I put this mess back together I can't open my rear widow, don't have back up lights, and the gear position indicater on the dash is not lite up. What's up please?
RE: transtrub;
Verify you hooked up the wiring harnesses on the drivers side of the tranny.
both the back up lights and dash indicator are feed off those connections. |
RE: transtrub;
Yea I would double check to make sure all connections are plugged in!!
RE: transtrub;
Yes everything is plugged in. I noticed that the switch unit is cracked between the two plugs, could this affect th connection? It worked before I took it apart. I ordered a new unit from ROCKAUTO.COM it should be in before the weekend. I'll let you know if this repairs the problem. Thanks.
| All times are GMT -5. The time now is 10:03 AM. |
