-   -   IS IT TRUE? (https://blazerforum.com/forum/engine-transmission-35/true-14239/)
murfthesurf4 11-06-2007 03:52 PM
IS IT TRUE?
:DWill my 95 4.3 vortec start with no problem and run though very rough with a bad camshaft or crankshaft sensor?
blazin97 11-06-2007 09:22 PM
RE: IS IT TRUE?
I know from experience that with a bad cam sensor it will not start, but on the crank im not sure.
murfthesurf4 11-12-2007 03:25 PM
RE: IS IT TRUE?
:)Thank you
nasty 4x4 86 11-13-2007 04:33 PM
RE: IS IT TRUE?
well not start just crank
thegr81 11-26-2007 05:34 AM
RE: IS IT TRUE?
With a faulty crankshaft positioning sensor it will start and run fine, I know this cause mine is currently doing this with the ses light coming on sometimes then turning off. Rcars2 has heard my motor run and the only problem we both agree I have is exhaust gaskets leaking a little bit!!
swartlkk 11-26-2007 11:01 AM
RE: IS IT TRUE?
I don't know why I didn't catch this sooner, but I'm cleaning this up now.
Everyone wishing to respond to the OP, please do so in the following thread: crankshaft position sensor
Other threads to be closed and pointing to the thread above include:
IS IT TRUE?
camshaft position sensor P0300
shaking!!
