Underside of chassis covered with Tr. oil
The under belly of a 2000 4x4 Blazer is wet with Trans. oil. The level is ok on dipstick, so maybe it just started,,, or has just shown up. The plastic cover shields on the left side catch the the oil, and so it puddled in several places. I have read about a front seal failure, that allows TR fluid to over fill the transfer case, if over full is it somehow forced out a vent or something ??? I also read about a transfer pump ring, knocking a pin hole in transfer case housing,,,, but I am thinking that is a different transfer case model, then what is on a Blazer [ like maybe that problem is a beeg truck trans and TR case problem ] So,,,, oil leak,,, almost looks like it is spraying or misting,,,, mostly on right side,, but follows covers on left side,,,, sort of a 'bomber' class vehicle,,, so may not merit a lot of $$$$$. Any ideas or thoughts would be appreciated. I washed it all off to try to see a source after a short drive.
Check the vacuum vent hose to see if there is transmission fluid in the tube. To find it, on the upper left side of the transfer case just above the front drive shaft output is where the vacuum switch connects. There will be 3 vacuum tubes connected to this switch, and one of them is the vent tube. It will vent somewhere just above the transfer case.
If there is fluid in the tube then the front input seal on the transfer case is bad and is allowing transmission fluid to be forced into the transfer case overfilling it. You'll need to replace that seal, and need to replace the vacuum switch too. Depending on how far into the vacuum system the fluid has gotten you may need to replace all your vacuum tubes and heater controls. Transmission fluid in the heater controls will kill them. |
I replaced that Vac switch on the trans/ transfer case last year,,, just a week ago, I replace the actuator under battery,,,, the old switch was letting oil sneak out, and finally killed the actuator,,,,,,,,, not sure when the actuator failed, as the 4x4 part gets very little use. plus the spiders gears went out too,, so that slowed down the use-age too. Spiders fixed now. But I will re-check all that,,,,,also.
Update: The transfer case was over-full a quart of oil came out of fill hole, then another quart when I removed drain plug. Refilled with about a quart, until it came back out of fill hole. So,, the transfer case seal that mates up to transmission is letting transmixer fluid leak into transfer case,,, how fast ??? I do not know yet,,,, when the transfer case gets too full, would that cause the fluid to ooze or leak all over the under side of Blazer ??? Is there a mechanical problem with letting it leak into transfer case,,,, since it is a low use bomber vehicle, why not just drain it once or twice a year to keep the underside dry ?
I guess my question is,,,, what is the harm of too much fluid in the transfer case,,,,,, ok,, oil is leaking out somewhere, but if that maybe is just coming out of the vent,,,,,,,,,,,,,,, so a longer vent hose may prevent that ??? Again, an ole' bomber vehicle,,, but do not like oiling the driveway,,,,,,,,,,,,,
The input shaft seal on the transfer case has failed. Timken seal # TMS 3173. Transfer case to adapter gasket fel pro # FEL 72769. Under $30 for both if you have a 3-button system. If you remove the seal housing, make sure it goes on the same way it came off. There is a divot in the housing that lines up with a hole in the T case for oiling the input shaft bearing.
That failed seal is allowing transmission fluid to overfill your transfer case. As El Beautor mentioned, the transmission fluid will ruin your vacuum system including heater controls if you don't have the auto climate control. Keep an eye on the transmission fluid level as it will go down. Good job on your diff. Those gears were BAD. |
sooooooooooo, can't blow off the transfer case seal,,,, ugh,,,,, my brain is wondering how too much oil in the transfer case gets into the engine vacuum system,, I get it, if that 3 port switch fails,, [ which was replaced] ,,,,, why would the engine draw a vacuum out of the transfer case,,,,,,,,,,, will rest over the weekend,, and consider the seal job next week,,, thanks Rusty-N , yup the gears were used up, that is true,,,,, not such a bad job, thanks to you guys, and you-tube.
not sure but I think as soon as you engage the 4 wheel vacuum it will pull fluid up to your heat/cooling vent system. Anyone can correct me if I'm wrong
sorta' what the guys are saying newguy,,,,, seems bizarre that engine vacuum could suck up fluid,,,,,but only if transfer case is too full,,,,, ????? almost easier to disable transfer case vacuum,,, use a cable pull to engage front axle,,,,, sort'a like lock out hubs control from the cab,,,,,again,, most of the time I do not Rube Goldberg things,, but this is a part time bomber class vehicle,,,, not a daily driver,,,,
By over filling and no excess room to flow the oil heats up, oil expands, hence spewing out the vent. Even in 2WD the O ring in the switch fails by having oil pressure and along with vacuum against it. The switch failing is the first fail it will also lead to case gaskets, seals for the drive shafts failures leading too eventually transfer case failure
How is this for the ultimate Rube Goldberg / Shade Tree mechanic fix,,, remove the T-case fill plug, install a hose barb-n-hose, run hose to a frame mounted radiator overflow tank,,,,,check over flow tank every week,, when full, put fluid back into Trans.
Or better yet, a windshield washer tank,,, when full hit a button,,, skirt fluid back into trans. Will check the numbers posted here,,,, and probably get the seals,,, might as well replace the vacuum valve again while under the vehicle,,, hopefully the week old actuator under battery is still dry,,,,,, |
Originally Posted by Rusty Nuts
(Post 662044)
Is there a good chance a bearing is also bad,,,,, that caused the seal to fail ? |
I believe the seals are the same. The letters are the manufacturer. I just copied the numbers off last fall's receipt from my local parts store. Double check for your application. The bearing is probably fine.
ordered a 3173 seal, and the 72769 gasket, 28 bucks or so ,,
Is there room to remove the transfer case , and leave transmixer in vehicle? |
If the transmixer is a transmission, then yes. Unbolt the transfer case from the adapter. I had to remove the transmission mount to get the bottom bolt.
thanks, Rusty,, I saw a video where a guy supported the transmixer with a block to support it while removing the cross arm the transfer case,,,, not a lot of you-tubes for a s10 Blazer transfer case removal,, but will take a break,, then tear into this Blazer,,, have my other son's Ranger in my garage now anyway,,,waiting for parts for both, so good time for a nap,,,,,,,,,
So,, we got the seal and gasket replaced,,,,,,,,,,,, the new seal was not exactly like the old one, but it fit,,, things just did not seem all correct,,,, since the gasket, went between the transfer case and the spacer housing [ for lack of a better term] we assumed the seal went on the shaft of the transfer case,,, the seal looked like it is made to keep oil 'in' the transfer case, instead of keeping fluid from entering ,,,,, [ by looking at the lip ] the spacer housing had a little fluid in it, but not much,,,, ???? If the transmission was leaking oil into the transfer case,,,, wouldn't that spacer housing also be full of fluid,,, ????? And should the seal also be replaced on transmission,, in front of the housing spacer ???? Back together now,,, will see what happens,,,??????????
The adapter housing between the trans and TFC is open to the trans, when running ATF squirts out the rear bearing in the case and splashes through there. When not running, it mostly drains back into the pan. There is no seal on the trans output shaft on the 4X4 700R4/4L60E transmissions.
The TFC input bearings rarely go out, the seals fail due to the rubber hardening and cracking. The seals we use have double lips, each one has the garter spring facing outward. Dunno the number, they fit most TFC input shafts. We get them from our parts supplier, Transtar. |
ok, I follow what you are saying,,, this is the seal and gasket we got,,, seal # 3173. Transfer case to adapter gasket fel pro # FEL 72769, like I said, it did not look like a double seal,,, so,, maybe it will fail very soon, or not fail, but just will not keep oil from leeching into transfer case,,,,, This Blazer also has HVA issues, as the selector does not change output,,, the under dash diaphragm seems to move to the limits,,, so do not think leaking oil is a factor with that,,, but I have read that leaking oil, then being sucked through vacuum switch can booger up the HVA system,,, next time we will retire the vacuum front axle engage, and replace it with a $25 hand-pull-locking cable from NAPA,,,,,,,,,,,,,,, since the 4wd has little use anyway.
