Sponsored by:
Sponsored by:
Unsolvable P1133
Old 12-16-2012, 07:48 PM
Little Roober's Avatar
Little Roober is on a distinguished road
Default Unsolvable P1133
So, I've been working on figuring out this code for the past week or so...
Bank 1 Sensor 1 not switching.
What I've done so far:
Replaced every vacuum line.
Bought 2 (AcDelco) sensors.
Cleaned MAF sensor.
Connections all look fine, however I don't have the tools to test them.
Background: I just had my transmission rebuilt 3 times by a very non reputable shop. Obviously, I didn't know when I first dropped it off...As soon as I got it back from them the second time, I got the code. I replaced the sensor and all was well. 3 months and 4 days later, I had to drop it off again and again was greeted by the code when I picked it up. Pulled the sensor, replaced it even though it had no deposits on it and looked damn near brand new. Ended up just replacing bank 2 sensor 1 with it... Code went away for 5 miles and has been there ever since.
I'm thinking my next step would be to check for an exhaust leak, maybe they left out a seal when they dropped it to take out the trans? Basically at this point just looking for what they broke.
Any help and opinions would be really appreciated.
Old 12-16-2012, 10:01 PM
xgiovannix12's Avatar
Not sure why you made a new thread
Oxygen Sensor / Vacuum Leak
But did you go thru the whole link I gave ya ? also did your hvac get fixed?
Old 12-17-2012, 03:34 AM
Honestly, I couldn't find it again. I wont know about the HVAC until it gets below freezing again. It's been 40+ here for the past 2 weeks.
I did check out the link, but I'm trying to figure out the most probable solutions...Idk.. I talked to a tech at a party the other night and he said it could be anything from the fuel pressure regulator to a leak in the upper plenum to a dirty MAF sensor. It seems like like I need a scanner to really pin-point the problem.
Bildo V.
11-21-2013 05:42 AM
drewb
06-02-2012 10:05 PM
jukeboxhorse
04-29-2009 11:28 AM
BlazerLove
01-21-2009 07:19 AM
Quick Reply: Unsolvable P1133
