-   -   Vacuum system (https://blazerforum.com/forum/engine-transmission-35/vacuum-system-90288/)
Regalj 07-21-2015 11:49 AM
Vacuum system
Just bought an 84 blazer 2.8 no vacuum inside to run vents etc any help? Tore dash apart everything is fine but can't find where it goes through firewall. They put a new carb on engine with electric choke so all of the vacuum is messed up. Overwhelmed don't know where to start.
CWBDDSPC 07-22-2015 05:56 PM
I've never looked under the hood of that era, but here are some vacuum diagrams from a quick Google search. I had an 81 cutlass with a broken line to the canister and that had the vacuum system all messed up until I found it...
http://www.justanswer.com/chevy/2kq0...-together.html
abig84 07-29-2015 01:15 PM
if you can see where the vacuum is supposed to go onto the back of the control head, you can always get all ghetto and just drill a small hole in the fire wall and run your own vacuum line
