Vibration in Gear,
Old Mar 5, 2025 | 10:21 AM
pistolstar's Avatar
pistolstar is on a distinguished road
Default Vibration in Gear,
05 blazer. Loud sound putting in R or D. Vibration. not as bad when come to a stop but its still there. One mechanic said water pump. Removed belt and vibration stopped. New motor mounts. One mechanic said slight miss. Can't keep replacing parts hoping to find the right fix..
211,000 miles. Replaced water pump 11/23. not sure if fan clutch was. Heading to mechanic who replaced pump. Totally frustrated.
Old Mar 5, 2025 | 02:42 PM
When you had the belt off did you grab any of the accessory driveshafts to see if they were loose?
Does the vibration frequency match the engine speed or wheel/transmission output speed?
Old Mar 6, 2025 | 08:40 AM
pistolstar's Avatar
vibration frequency seems to be constant. . Speed doesn't change
farley463
Jan 29, 2014 04:51 PM
2000Blaz
Jul 29, 2013 09:14 PM
Jakeduece
Apr 12, 2013 01:41 AM
bobtrub
15
May 6, 2010 08:51 PM
4thgenssuck
Jun 27, 2007 12:10 PM
