Community
Search
Sponsored by:
Sponsored by:
violent jerking
Old 03-05-2013, 09:25 PM
swanman35 is on a distinguished road
Do you have any rough estimate of what it would cost me to have it done at a shop? If I happen to get it timed correctly myself will I NEED a scan tool to get that done?
Old 03-05-2013, 10:05 PM
Captain Hook has a spectacular aura aboutCaptain Hook has a spectacular aura aboutCaptain Hook has a spectacular aura about
You should be able to get the distributor in correctly and get rid of the P1345. It's probably only off one tooth, one direction or the other. Labor to check & adjust camshaft retard should be under 1 hour. Yes, it requires a high end scan tool capable of accessing the camshaft retard streaming data. The el cheapo $500 jobbies cant access it.
Old 03-06-2013, 01:00 AM
Ok, I'll have that done sometime soon. You were great help, thanks! I'll update when I get everything in order
Old 03-06-2013, 02:31 PM
Took it to a mechanic today and he said "you re getting a code here that means you need a new positiin sensor." I told him that I got a p1345 and that I thought it just needed timed correctly. He told me that wasnt the case and that it would be $120 for the new position sensor along with labor to get it fixed. Is what he said true? He seems kind of shady, but can a p1345 be because of a faulty position sensor?He also said "these 4.3's are known to have this issue" which I've never heard anything of until today.
Old 03-06-2013, 04:15 PM
DTC's NEVER tell you that a part needs to be replaced. The P1345 means the camshaft to crankshaft correlation is incorrect. In other words, the distributor is not meshed correctly with the camshaft. If the camshaft position sensor had a problem, you would get a DTC relating to the camshaft position sensor or its circuits. Find a new shop.... SOON.
Old 03-06-2013, 09:22 PM
That's what I thought. I told him I would get back to him later. I talked to some friends and i guess he isn't a very reliable mechanic. I was wondering why he wouldn't let me see the scan tool. I paid him $25 to lie to me..
Old 03-06-2013, 09:56 PM
I am going to take it to the local gm/chevy dealer and have them look at it, maybe tomorrow .
Old 03-07-2013, 04:09 PM
The dealer will have the Tech2 scan tool, (GM factory dealer issue). Whether they have a technician that knows how to read it and do the adjustment is another question. Just because it's a dealer, is no guarantee. Good luck!
Old 03-07-2013, 09:03 PM
Well, if they don't then I'll have no.choice but to take it to the crook.mechanic.. thank you! I'll need it
Old 03-07-2013, 09:08 PM
Trust me, if you go back to him, you'll get nowhere fast. HE is supposed to be the expert, and he won't take kindly to you telling him how to do his job.
Quick Reply: violent jerking
