Water pump
Old Dec 6, 2020 | 09:45 AM
azrealazitgetz's Avatar
azrealazitgetz is on a distinguished road
Default Water pump
Water pump has a hole on top and it sends to be leaking from there. Overheating problem, water leakage, any suggestions.?
Old Dec 6, 2020 | 11:31 AM
Replace the water pump? Maybe flush the cooling system and replace the thermostat at the same time.
Old Dec 7, 2020 | 05:18 AM
I was told by my mechanic that if it starts leaking from one of those hole, that the pump is starting to go...
That was my case, truck started to over heat, but pump was somewhat still operational. Swapped the pump out with a new one, and all is perfect again.
How old is the pump?
Old Dec 10, 2020 | 06:47 PM
YoureATowel's Avatar
YoureATowel is on a distinguished road
That hole is what’s called a “weep hole”. It’s placed there so that when the water pump has to much pressure it can release it without blowing apart. It’s normal to have a little here for there but not leaking. It’s definitely starting to go. How long will it last? Don’t know, but I’d definitely replace it soon.
NEW YORK BOY
Apr 10, 2011 09:52 PM
Jeremy1769
Apr 16, 2010 10:05 AM
quick 51
Aug 3, 2009 08:33 PM
2001BlazrLS
Jun 29, 2009 08:02 PM
S10Blazer
Nov 27, 2007 09:04 PM
