-   -   water pump help!!! (https://blazerforum.com/forum/engine-transmission-35/water-pump-help-82922/)
chevy77 11-24-2013 05:28 PM
water pump help!!!
is it absolutely necessary to remove the fan clutch to change the water pump i rented the tool from auto zone and i dont know if its too tight or seized maybe but all i managed to do was round off the bolts and the tool i did notice the piece that fits on the clutch itself is a little too big but that is the only one they had to fit and thats the one it requires ive changed these on blazers before but this one is a bravada which i think is the same but i cannot get the fan clutch off any advice please
rexazz2 11-24-2013 05:33 PM
take a look here
https://blazerforum.com/forum/articl...-thread-24597/
chevy77 11-25-2013 07:56 AM
i know how to change the water pump i just need to know if its possible to change without removing the fan clutch because this one will not budge
rexazz2 11-25-2013 06:50 PM
yes but once off the block it will be nearly impossible to hold even with a vice
If you don't get it apart you will need another clutch , pulley and fan blade
Not sure if that is a regular or left hand thread, check new pump to confirm
Is it possible your trying to tighten instead of loosen ?
KM346 11-25-2013 07:12 PM
The autozone tool will not work for our trucks. As mentioned, do not remove the pump with the clutch attached. It will only be more of a PITA.
I made my own tool out of a piece of steel that bolts onto the pulley/pump to hold it when loosening the clutch (I've always just used a big crescent wrench to do so). They're standard threads BTW, so righty tighty lefty loosy applies lol.
07nhbpsi 11-25-2013 07:38 PM
It's reverse threaded
KM346 11-25-2013 08:37 PM
Not sure where you got your info but that's wrong. They are right hand thread....
chevy77 11-26-2013 08:50 AM
so if i can find a big cresent wrench for the fan clutch what do i hold the pulley with could i just wedge a screw driver between the bolts or will that be enough to hold it in place
newguy 11-26-2013 09:09 AM
Yes big screwdriver or prybar, get someone to hold that, then whack the cresent wrench with a BFH.( Big f Hammer) counter clockwise
07nhbpsi 11-26-2013 01:10 PM
Really??? I couldve sworn it was ??? This was awhile back , but i seem to remember it being this way!??? Oh well, maybe a few too many beers at the time!!!! Lol
