Water pump? Hydra locking? IDK HELP!
Okay Begin with 2001 S-10 Blazer 2WD 4.3L 6 Cylinder Vortec. Water pretty much pours from the water pump, best i can tell is right behind the pully. I replaced the water pump 2 years ago but now its out again...belt seems to have proper tension. I did not replace the fan clutch when I replaced the water pump, could this have caused my bearings to go out? And occasionally the engine just makes a loud clunk when I try to start it but I cranks after 3-4 clunks. Is it trying to hydra lock, or are the bearings on the pump bad enough to cause the belt not to turn. I am driving this 1.3 miles to and from work each day, gingerly. I am off sunday so planning on changing the water pump but I need to know if it is hydra locking and if so how do I fix it. And also the logical reason for the pump going out so soon? THANKS
Concerning the pump... Sounds like a poor quality pump that failed on you quickly? The system cannot hydro lock since it isn't a positive displacement pump rather, it's a centrifugal pump.
Your starting issue could be a number of things, least of which, IMO, is the water pump. |
Well I have had a slight water leak for a while, but was told that when these pumps go out the leak water to let you know the bearings are out. Im assuming it just escalated finally on me. Also I was running straight water no coolant in it which could be another reason the bearings shot. So sunday I am changing the water pump, fan clutch, flushing the radiator, id like to do a tune up but never done one, any advice on that? Changing the oil. I am very mechanically inclined just no experience, if I can get it off I can put it back together. What do I need for a tune up and how do I do it?
Thanks |
Originally Posted by Jeremy1769
(Post 322040)
...Also I was running straight water no coolant in it which could be another reason the bearings shot. So sunday I am changing the water pump, fan clutch, flushing the radiator, id like to do a tune up but never done one, any advice on that?...
| All times are GMT -5. The time now is 04:20 PM. |
