Weak Start, 95 Blazer
My truck has a new starter but when I try to start it it cranks and cranks and then starts. When its colder out or the truck has been run within say 5-10 mins it fires right up.... any ideas on what causes this?
Test your fuel pressure and CLEAN YOUR EGR VALVE. Could be the exact same cause for the idle quality problems you are experiencing in your other thread --> Horrible idle!?...
My mechanic heard of my problems and asked me to take it in after school tommorow before i go to work so ill have to mention it
Did it start doing this with the new starter? When it cranks, does it sound like the starter is bareley getting any juice? If so, you may need a new battery with a higher cold cranking amperage.
No the starter is strong, I just found out the "spider" is bad, the poppets are cracked and its gonna cost me 400$ to fix, idk what to do I cant afford it
Onto a new thread without any history...:rolleyes::(
Whats the spider?
The fuel injection system, they call it the spider i guess lol, i guess some of the poppets crack which is leaking fuel into my engine causing all my problems, bad plugs, running rich, bad idle
Ouch. Tough break. Any ways to prevent this guys?
I really dont think there is anything you can do about it, its just something that happens with age, plastic cracks over time
| All times are GMT -5. The time now is 11:24 AM. |
