weening sound
Hey everyone, hows it goin? So my 01 extreme makes a weening sound when I drive. It has gotten louder and worse. I hope its not the trans. It makes the sound when I am coasting in nuetral also. It gets louder the faster I go. Does anyone have any ideas whats up? thanks
RE: weening sound
maybe belts or pulleys or alt/ac/waterpump etc.?
RE: weening sound
thanks rooster. So what is my best way to find out what this sound is. Do I need to take it in somewhere?
RE: weening sound
I'm not sure what a "weening" sound is but if it gets louder with increased road speed, it could even be axle grease seals that have dried up.
Can you locate the area of the sound? |
RE: weening sound
Are you completely sure it is speed related?? Weeening sounds like alternator bearings...do you have underdrive pulleys??? Sometimes if the pulley does not rotate the alternator to specific speed then your electronics can't work their best. Todays electronics demand a lot from the alternator. If it gets to hot then it will fail...
RE: weening sound
well i took it to a place and he said it sounds like it could be my wheel bearing. He said it usually is not that high pitched as it is but he thinks thats it, says I have to get new assembly, says it costs 350. Is this accurate? Does it sound like this is the problem? anyone?
RE: weening sound
Yes, it might be it. Don“t know about the price though, as I live in Sweden and things cost a lot more here...
RE: weening sound
Could it be the altinator? I know when mine was bad in another car, the faster I went I heard a noise like that. Maybe get that tested just to be sure. Or are you sure its coming from a specific area?
RE: weening sound
Does it do it with the stereo off? That's the only place I've heard a "weeeeening" sound, from having a bad amplifier ground, or bad plug wires...
RE: weening sound
ORIGINAL: drperry Does it do it with the stereo off? That's the only place I've heard a "weeeeening" sound, from having a bad amplifier ground, or bad plug wires... |
| All times are GMT -5. The time now is 05:06 AM. |
