What fluid and how much for front diff and transfer case?
i dont know why i didnt think about this until right now but, you could just pull the fill plug on the transfer case and stick your finger in there. dont worry, its not going to cut off your finger. get some fluid on there and give it a smell. when you are done with that, wash your hands and then go look in the mirror so you can get it off the end of your nose. lol.
if it smells like atf, then you know what you need, same thing with the gear oil. your front diff is gear oil, but i dont know how much. just buy a gallon of it and do the rear end first and refill it. then do the front and if its not full when the gallon is empty, (it should be, but like i said, im not sure) you can drive it to the store at that point in 2wd and get anything that you need. just dont forget to top it off.
can anybody help me out with this? id like the get some fresh fluid in the rear axle
i can loosen it and break the seal slightly and let it drain out, and clean it all up and what not and put the new seal and cover on, how do i refill it?
Flyfishen
Jun 18, 2019 11:22 AM
ComputerNerdBD
Jan 14, 2012 12:07 PM
Brianator99
Aug 30, 2009 06:18 PM
aaron.b
Aug 11, 2009 12:06 PM
DaleA
Jan 13, 2009 08:50 PM
