-   -   Whats the difference between Sonnax .490 boost valve and Transgo .500 boost valve? (https://blazerforum.com/forum/engine-transmission-35/whats-difference-between-sonnax-490-boost-valve-transgo-500-boost-valve-52627/)
bigdaddykane93 12-12-2010 01:09 PM
I know there is an advertised .010" inch differnce between the two, but is there any other difference between the two? and which is better for a stock transmission with some wear on it? and does one give more line pressure than the other? and does it affect idle line pressure too? i appreciate any info or advice , thanks
swartlkk 12-12-2010 02:56 PM
The stock boost valve is 0.470" in diameter. Both the Sonnax and the Transgo valves will increase line pressure. Sonnax states a 10-15% increase in line pressure. I wasn't able to find the increase for the Transgo valve.
bigdaddykane93 12-16-2010 12:27 PM
hi Kyle, would you know if these boost valves will boost line pressure at idle too? or only as the rpm or throttle increases? only because i dont want high line pressure at idle because then i will have a hard engagement. and would the .500 boost more than the .490 since its bigger ?
swartlkk 12-16-2010 04:28 PM
I'm not sure on idle line pressure, but I would assume so.
It also stands to reason that the .500 boost valve would increase the line pressure more than the 0.490 boost valve.
