Where is the coolant going?
This post is in regards to a previous post. (https://blazerforum.com/m_136934/tm.htm
After changing the intake manifold gasket, t-stat, rad cap. On Sunday everything was fine, no over heating and good heat, until today (Almost a week later), when i got home the lower rad hose was collapsed, and the coolant was low (about 1/2 rad). Where is the coolant going? It went a whole week without a problem, there are no visible signs of leaks (That I Can Tell)and no smoke coming from tailpipe. I don't know what to check next, or where to ever start. Help!. Any suggestions or ideas? Once again Thanks in Advance! |
RE: Where is the coolant going?
I'll reply to your original thread.
No need for a new thread on the same subject...
*Thread Closed* |
| All times are GMT -5. The time now is 09:32 AM. |
