Whirring Noise While Revving from PS Pump Area
Alternator, tensioner, idler pulley, those are all pretty easy fixes and we all probably have done them at least once. If you do end up fixing your rig in the parking lot at the parts store, you should be sure you have all the tools you need with you so you can do the repair quickly. Changing out the PS pump would be a chore. Keep the fluid full for now and it could last quite a bit longer.
I once impressed a friend when I came back from a trip to the airport in the city 90 miles north of where I lived to find my alternator was bad. We got my truck to her family business's shop and then we got a new alternator at a parts store. I was able to replace it using the tools in my truck in about 30 - 40 minutes without even breaking a nail! LOL
As for the tensioner and Idler, yeah I'm not worried about those. I am still concerned with the P/S pump, though at this point I'm not completely certain the noise I started hearing was from it after all. I'll really only know once I get the new pulleys and alternator in.
As for tools, I have a full set (mostly, it's uhh... dropped a few bits and bobs over the years) of Snap On socket wrenches I keep tucked away in the back. They were a gift from my GM mechanic uncle, and they've served me very well over the years, though I need to replace them sometime cause, well, a LOT of bits an bobs have gone missing to the point where it's sometimes a hassle.
So, in the end, I've replaced the tensioner, alternator and idler pulley. The noise I thought was the P/S pump is now gone, and when I got the idler off, BOY was it shot. I think it was my noise culprit.
Everything runs perfectly now, thankfully. I've bled a few times from this project, but it's worth it. It always is.
Three things I replaced.
For those interested, this is the crappy old idler pulley. Enjoy the incessant metal on metal grind.
https://drive.google.com/open?id=1XK...up6sDrWs4B66Qw
I am glad this worked out for you. I had the opposite experience I fixed the tensioner and idler and rerouted the belt correctly then the PS pump started making noise and throwing the belt.
Found the PS pump had been replaced and the three bolts that hold it on the bracket were missing. I fixed all that it runs like a champ.
Sadly, after all this work... IT STILL SQUEAKS!
Only when it's cold, and not very much at all. But I'm annoyed. I'm going to try one of those Gatorback belts everyone on this forum talks about, and see if that removes it completely. It... it's not really an issue any more I don't think, but it's the principal of the thing! Once my front end is fixed and stops sounding like a broken squeaky toy itself, I want this thing to just start up and purrrrrr. It may be a nearly 21 year old vehicle, but I'd like to revitalize it. Can't make it look nice when it don't sound nice!
Granted, the piston slap on start up will probably never go away. -.- Can't have everything, I guess.
ComputerNerdBD
10-15-2013 12:03 PM
ant2297
10-01-2010 11:44 PM
