-   -   will a shift kit help? (https://blazerforum.com/forum/engine-transmission-35/will-shift-kit-help-18341/)
firemansc32 03-14-2008 06:11 AM
My trans slips in second gear under hard accelration but not at all under normal driving. Would a shift kit slow the demise of the second gear clutches or do nothing at all. I could afford the shift kit but not even come close to a rebuild.
[align=left] [/align]
Chevy Lover 03-14-2008 11:39 PM
RE: will a shift kit help?
I rather doubt that it would help now if it's already slipping. If you had it installed before the wear occured it could have been worth the money.
WolfPack 03-15-2008 01:31 AM
Oh! You've piqued my interest sir. What all is involved with these shift kits...and how do they work exactly?
swartlkk 03-15-2008 08:18 AM
A shift kit is basically a hydraulic reprogramming of the transmission for quicker, firmer shifts. When done to a healthy transmission, it will prolong its life. Most of the heat and wear generated inside the actual transmission (torque converter aside) comes from the slipping that occurs during a shift.
If you do not mind having shifts that may be classified as harsh to neck snapping (depending on the shift kit setting you choose), a shift kit is for you!
Chevy Lover 03-15-2008 12:59 PM
^^^ As Kyle says, it's basically a hydraulic reprogramming. This involves pulling the pan, dropping the valve body, changing a few check balls to alter pressures.
I have a shift kit in my '90 and it has a head snapping shift. I like it, but I don't take my 82 year old dad out in this truck. :D
4x4blazerguy 03-15-2008 01:43 PM
I agree with those that feel a shift kit improves transmission performance on a health tranny. But once a tranny starts slipping the best is to take it in for repair before you cause MAJOR DAMAGE. Personally, anytime I have to rebuild a tranny for myself a shift kit is a must. The other improvement that isn't talked about much is a performance torque converter, like HUGHES or B&M. For standard use & off-road I like the towing converters made by HUGHES PERFORMANCE out of Phoenix. They reduce converter slippage, which in turn adds to torque & less heat. Also another help for healthy tranny's is LubeGard ATF Additive. It cuts heat according to many tranny guys I talk to. Many tranny shops recommend it & or add it to their rebuilts.
firemansc32 03-16-2008 01:33 AM
Well then does anybody have a guess as to what a rebuild would cost me.
I though about this but it is a little overkill. http://www.bmracing.com/index.php?id...&subcat=19
