Wont Start After Intake Manifold Gasket Change
Old Jan 11, 2017 | 07:32 AM
LesMyer's Avatar
Originally Posted by Fatguy9
So I should have pulled the spark plug out and checked like that, I took it to a mechanic and he said the timing was off and that the marks on the balancer were off, Has any one even heard of that before? (im 100% sure i matched up the lines to TDC) Well anyways it runs now and im a few hundred dollars more poor. Thanks for all the help
You may have had the distributor in 180° out. It's a 4-stroke engine. Engine turns over twice for each distributor rotation.
Sounds like the mechanic may be confused on timing marks and what to line up (rotor points to stamped 6, not #1 terminal when engine is at TDC#1 on compression stroke), but nonetheless if the SES light is functional (comes on with KOEO) and it is not on with the engine running - then the distributor is definitely in on the right tooth and he did a good job for you no matter how he accomplished it.
awesomeamerican1
Dec 6, 2014 12:01 AM
dmac122
Nov 21, 2011 04:07 PM
c.andrew
Oct 28, 2009 01:28 AM
jspafford
May 27, 2009 09:03 AM
brinriha
19
Apr 14, 2007 05:12 AM
