wont start when hot
Old Oct 25, 2010 | 09:46 PM
stuckinthemud73's Avatar
stuckinthemud73 is on a distinguished road
Default wont start when hot
any 1 familiar wit there blazer not starting when hot????
Old Dec 21, 2010 | 10:50 PM
gionet331's Avatar
gionet331 is on a distinguished road
i've been browsing the forum a bit and it looks like there's a lot of people with the same problem,cause i have the same problem.
Old Dec 21, 2010 | 11:21 PM
84BlazerS10's Avatar
More information might help you find an answer. What kind of car is it?
Old Dec 22, 2010 | 12:20 AM
gionet331's Avatar
cherokee 1989,with a 4.3 i change the spark plug,the 2 injector,cap timmer and rotor,coil.and when its geting hot it spray gaz like crasy that i had to change the oil and filter,and i also change the o2 sensor,i'm on the edge of junking it,it getting expensive.
Old Dec 22, 2010 | 06:51 AM
What did the motor come out of? It sounds like a TBI engine, but to assume... In order for us to help, you have to provide information.
Old Dec 22, 2010 | 09:12 PM
gionet331's Avatar
i'm very new with that kind of motor,i bought that 1989 cherokee for scrap but it was not running good at first so i bought and other one it is a 1991 blazer,so i took the part from the 1989 and i put the missing part on the 1991,and all summuer it was running very good and when it was time to put the plow in front it start running bad,when the 1991 was getting hot it spray gaz like crasy and i had to change the oil and filter,and i change the injectors,coil,cap timmer,rotor,and the o2 sensor,it was the same,spray to much gaz in the injector,so i took the part again and switch to the 1989,when everything was change the same thing happen,spray to much gaz when getting hot,now i dont know what to change,its getting expensive.
Salviracing
Aug 19, 2015 06:30 PM
Mandrwj
Apr 10, 2011 07:32 PM
muddin84084
Aug 4, 2009 06:55 PM
ravenhurst
15
Apr 26, 2009 07:53 AM
blaze92
Dec 29, 2007 01:36 PM
