-   -   Worn Speedometer Cable? (https://blazerforum.com/forum/engine-transmission-35/worn-speedometer-cable-53240/)
mscollins47 Dec 27, 2010 10:48 AM
what are the symptoms of a speedo cable that is on its way out? I think thats what is happening....lots of buzzing/intermittent when driving, gets worse when using accelerator, usually stops when stopped or slowing down. My old cavalier had same thing and I was told it was a speedometer cable. No issues with actual meter though.
swartlkk Dec 27, 2010 02:53 PM
What are you driving?
mscollins47 Dec 28, 2010 07:14 PM
2002 blazer, 2 door, 6 cyl
swartlkk Dec 28, 2010 08:15 PM
You do not have a speedometer cable. The speedometer uses an electronic sensor in the back of the transmission (2wd) or transfer case (4wd).
Your problem is likely the cruise and/or throttle cable resting on the PCV hose and transmitting the noise from the PCV valve in through the throttle cable.
