1986 k5 blazer steering slop
Old Apr 3, 2011 | 09:03 AM
aj713's Avatar
aj713 is on a distinguished road
Default 1986 k5 blazer steering slop
How do I change the steering box? I cant believe the original owner was driving this thing with 6 inches of slop in the steering for years!!!!!
Old Apr 3, 2011 | 09:14 AM
helo's Avatar
helo is on a distinguished road
unbolt it? You can adjust the bearing preload to take the slop out once it's off the frame.
Make sure your balljoints and tie rods are good.
a new AGR box is the path you want to take if you want a replacement box (check summitracing.com). Or, you can send your box off to redheadsteering. A parts chain "reman" box will be just like yours, only adjusted, cleaned up, maybe painted, and possibly with a new seal... When you turn yours in as a core it'll be for sale again without undergoing a full rebuild.
Jegs and summit both sell replacement rag joints, too (the rubber disc).
Old Apr 3, 2011 | 02:36 PM
You'll also want to inspect the frame behind/around the steering box. A lot of them like to break out around the box.
PhilBilly
Feb 2, 2020 11:13 AM
bam_9_9_9
18
Jun 17, 2015 01:49 AM
T...K21
May 21, 2013 11:06 PM
Eric Johnson
Aug 29, 2012 08:42 PM
PMeloy
May 10, 2011 03:37 PM
