1990 chevy blazer won't start unless gas in carb
okay so i put gas in the carb, and it starts right up for a few seconds. i replaced the fuel pump and the fuel filter then it ran great, then it just quit starting after about a week or so, it will only start if i pour gas into the carb. any ideas would be great. thanks
Can you see fuel squirting out from the injectors on the throttle body?
i thought about checking that today but it doesn't run long enough to run around and check, but i could have a budy start it then i'll check. if not then ..?
Remote starter trigger. $12.00 at Autozone. Then you can stand right there and turn of while you're watching it. Try HERE.
