-   Full Size K5 (1969-1991) GMT415 (1992-1994) Tech (https://blazerforum.com/forum/full-size-k5-1969-1991-gmt415-1992-1994-tech-42/)
-   -   1992 Fullsize Blazer Frame Swap (https://blazerforum.com/forum/full-size-k5-1969-1991-gmt415-1992-1994-tech-42/1992-fullsize-blazer-frame-swap-51576/)
yalpngulp Nov 15, 2010 10:00 AM
Hey guys, new to this site. I hope i'm posting in the right section.
I have a 2 door full size blazer 4x4. A tree hit my truck head on and bent the frame as well as 1 fender, rad support, bumper etc... I really love this truck and was wondering if any other 88-98 frames will be compatible with it. Body and paint is fresh and the truck is perfect from the doors back, so i was hoping to swap the body to a donor frame and replace the front end from the donor to make it complete again. Any ideas on what frame will work for this?
swartlkk Nov 15, 2010 09:26 PM
'92 was the first year for the IFS. As such, you can only use a frame from a 92+ two door Blazer/Tahoe/Jimmy/Yukon.
yalpngulp Nov 16, 2010 08:16 AM
is there any other frames that would fit? could I cut the front half off a 4x4 pickup and graft it on?
Ebony girl Nov 16, 2010 11:38 AM
Hey,
You can use the 95 frame of the tahoe or yukon
up to the 97
I believe the frame was made alittle smaller in 96 or 97
swartlkk Nov 16, 2010 12:04 PM
You do not want to get into trying to graft two frames together unless you really know what you are doing.
yalpngulp Nov 16, 2010 02:00 PM
Ebony girl Nov 16, 2010 02:50 PM
I guess so, sounds kinda complicated though
sounds like you can buy a used shell, and rebuild it from the inside out
