6inch the max lift for ifs?
i agree with tibby, solid axle is the only way to achieve this and be happy with it. ul prob save money doin a sas too, at first and the long run. ifs lifts bigger then 6" tend to break stuff ez when running monster tires and sum carriers and gears can be expensive for ifs housings compared to solid axles. dont waste ur time on an ifs lift bigger then 6", plus they look absolutely hidious, imo.
I'm in on the sas bandwagon. Honestly I wouldn't lift ifs over 3 inches anyways. Ifs is only designed to run factory sized tires and even only 2-3 inches bigger is stressing parts. For a fullsize axles are easier to find and swapping is cheaper if you have a welder and know how to use it.
