-   Full Size K5 (1969-1991) GMT415 (1992-1994) Tech (https://blazerforum.com/forum/full-size-k5-1969-1991-gmt415-1992-1994-tech-42/)
-   -   88 k5 flywheel noise (https://blazerforum.com/forum/full-size-k5-1969-1991-gmt415-1992-1994-tech-42/88-k5-flywheel-noise-59029/)
deathman 05-15-2011 08:03 AM
i have a 88 blazer 5.7 tbi ,700r4 trany . i noticed some noise under the truck , sounds like its comming from the torque coverter , i pulled the inspection plate and noticed my flywheel has a wobble to it , the truck runs pretty good but lacks power , could this noise get picked up by the knock sensor and retard my timing ? also what else could be making that noise? torque converter,flywheel, trany pump ? torque converter bolts r tight , the flywheel wobbles but not the converter, any help or ideas would b helpfull thanx :icon_doh::icon_doh:
swartlkk 05-15-2011 09:01 AM
Could be a warped or cracked flex plate. A noise from the flex plate could be picked up by the knock sensors.
Z71_Guy 05-15-2011 09:03 PM
i would start with a flywheel i dont think there supposed to wobble
Gimpy Blazer 05-17-2011 01:05 AM
No they're not. Also check for loose bolts and oblong holes if the bolts are loose as well as the aforementioned cracks. Had a 82 2WD truck with this problem.
